Quite amazed.
TJExcalibur
Out of this world.
Southern England
I happened to come across the VU+ pvr for android whilst looking to see if I could run my 36v motor using USALS. Never found out as I was distracted by the VU+ pvr. I popped it onto her Xperia tablet and it worked a treat, seemed to be better than the XBMC VU+ pvr on android.
Trust
Nijmegen Netherlands
And now you run your 36 v motor by Usals ?
What kind of motor do you have , H2H or actuator ?
TJExcalibur
Out of this world.
Southern England
No I don't. Its a 36v H2H and I was looking to see if there was an add on to save setting it up sat by sat.
I did a factory reset on my GB quad and went to reinstall the settings but discovered "SHE" had borrowed by usb stick and formatted it.
Trust
I have managed to make usals work with the small 36 v Fibo motor and a very unknown RM120 , both H2H .
Even a SMR1224 should be possible .
Its crucial to let them make 39 pulses / 1º
What brand/type motor do you have ?
TJExcalibur
Out of this world.
Southern England
Ye Gods, I will have to go on the roof to be sure but I think its a Jaeger.
