Reading \ Streaming from one STBs E2 bouquet to another
Manikm909
Small'ish Dish Man
Kent, UK
Hi Chaps.
So i will make this simple:
Info:
STB1 (E2) - has 2 sat feed connections from 28.2e - and is on my LAN.
STB2 (E2) - has NO sat feed connections, and is also on my LAN.
Question:
Is there a way to VIEW the sat signal \ over an IP stream from Box1 to Box2 - I was thinking if Box2 could read BOX1's bouquets, that would sort it, it would stream them effectively.
Thanks for your time.
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Partnerbox works, on openatv images. You have to enable fallback tuner.
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
It's certainly possible on the Vu+ boxes I use. On there it's under Setup > Service Searching > Remote channel stream converter
You may need to give more details on your box and the image used for specific instructions.
You may also want to assign fixed IP addresses for your boxes to avoid issues after a reboot.
stel883_
Vátika, Greece
Also, the receiver sharing tuners, must be in standby mode. Or disabled.
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
On my Vu+ box as long as there is a free band (H/V/Hi/Lo) another box can use the tuner.
stel883_
Vátika, Greece
One advantage, i saw with partnerbox, was it could read an official cam with subscription (Tivusat).
7mdish
Milan, Italy
Another good solution could be an E2 box (STB1) and a "streaming" box (STB2) like AppleTV or, I believe, Firestick.
I completed successfully such configuration using my Dreambox DM920 and my AppleTV 4K.
Using the right app in the AppleTV, it is possible browsing the bouquets stored in the Dreambox, selecting the desired channel with the AppleTV remote control.
And obviously you can change channel every time you want.
It works with encrypted channels too (if the Dreambox provides the right CAM and/or card).
Remember that the STB1's tuner would be used by the STB2 one, so it is not available on the first box.
No experience with the firestick but I believe it would be the same.
stel883_
Vátika, Greece
Also, there is ChannelsImporter
Manikm909
Small'ish Dish Man
Kent, UK
THANK YOU!
This is amazing!!!! Working spot on.
I'm so glad i asked the question.
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
THANK YOU!
Glad you got it working! It is amazing and it took me over a year to work out it was even possible but it's so useful.
