Receiver Identification Help
MIB8508
I dont know it yet
Hi Guys.
Could someone help me identify my receiver.. I dont know what model it is..
I think it might be a Technosat 1100 because that is the remote controller I use for it... Only thing is, when I look for images of the Technosat 1100 I get different looking receivers to the one I have..
anyways I managed to find an image of my receiver. I have attached it to this post.. Would appreciate if someone can tell me what the hell kind of receiver that I have.
Thanks.
hexah
Hadrians Wall
There should be a label on the back or underneath.
MIB8508
I dont know it yet
Hi mate. Thank you for the reply.
There is only one lable, and it's a barcode number.. DJ0507005601
hexah
Hadrians Wall
Try contacting Technosat as they will be the only ones able to decode the barcode for you.
