Receiving Sky+ in North Germany...
kiel-bear
North Germany
I have been thinking about changing to Sky+ I am using a PanasonicTU-SB30 receiver at present, which I bought on Ebay to replace a Grundig Digibox which couldn`t receive weak fringe signals.
My question is .. Which Sky+ box has a sensitive tuner that works well in area`s with fringe reception.
Thanks in advance for any advice/help.......
indios_se
www.skyforeurope.com
Sweden
just get a v2 sky + box, it will outperform the dsb-30 quite easily.
both the pace and amstrad version 2 is supposed to be very good.
the v1 sky+ is ok, but not as good as the v2
remember you will need an lnb with dual-output to use sky+,
so dont forget to buy that too.
regards
Richard, skyforeurope.com
