harmio
Hi guys, I am a student in halls with a freeview box ( digihome 24.99 argos), and one of those space age looking aerials, u know, the loop aerial with the two extentable prongs either side , with booster in built
I am using this site as a reference for channel and mux info:
http://www.ukfree.tv/txdetail.php?a=TA040869
I am recieving freeview from "oliversmount" transmitter in scarborough. Even without boosting the signal I am getting 80% signal and "very good" quality rating on bbc mux C49, 80% on abc/five mux on C54 (which, according to the site, has a very low reception rating) , I am also getting similar on C61, Sky mux.
I cannot even lock or get ANYTHING for ITV on C67, although its of a higher power than the five mux, I also can't get C58 bbc4, or channel 64. I thought perhaps it was an aerial grouping issue, apparently I need C/D and the aerial was weakening on higher frequencies, but its strange that C61 is so strong, get C58 is literally non existent. I also thought it could be 64QAM etc issues but the muxes i cant get arent just 64QAM, infact its only the one .
It's strange because its as if there is nothing coming through on these frequencies at all, yet the others are perfect and high level robust signals. any advice guys?
