B16MCC
Dreambox Gimp & Coder
- Nov 16, 2005
- Age
- 51
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
- /var/tuxbox/config
Hi guys, here's my latest creation. The Dreambox 1 Click Setup For Sly UK.
1. Who's it aimed at ?
It's aimed at new dreambox users who want fast results without spending hours reading about channel bouquets, cam installation and the like. In this very early stage there is support for Enigma2 boxes only.
2. What does it do ?
a. It installs the Sly UK EPG listing with the channel numbers matches perfectly.
b. It installs CCcam 2.1.4 without using the images addons panel.
At the moment it does not create a boxkey or CCcam.cfg but that will be introduced in the very next beta release.
This windows .NET compliant utililty will setup an E2 Dreambox to use Sly UK with 1 click of the button. Simply flash your box with a new image,run though the setup wizard and enable the network connectivity. Then run this software.
What's to come from this software :-
Enigma 1 Support (looking for beta testers please.)
Automatic box model detection.
Integration of boxkey and CCcam.cfg file creation. (taken from the Dreambox Config Creator)
