mesaka
Hi all,
My second satellite box is two floors higher than the room where I watch TV. I normally watch it using a wireless transmitter while my other satellite box (in the same room as my TV) is used almost solely in conjunction with my TiVo.
The wireless transmitter is not that good and, as I have a CAT-5 lan connection between the two rooms, I wondered if it was possible to connect the systems via the LAN. I've done some initial scouting and I can find systems which use Cat 5 cable but there require a dedicated cable which I don't have and am not likely to be able to put in very easily. Can anyone suggest an affordable IP based solution?
