Terryl
- Apr 14, 2011
- Age
- 83
Custom built PC
- Deep in the Boonies in the central Sierra Nevada mountains of California.
Hi, thanks for all the replies.
I am indeed in the UK, South Wales infact.
I am going to rerun a new cable anyway but It seems odd that I do not get anything at all. If the dish is out of alignment even slightly, would I still get some 'quality'?
The motor was fed by 36v it looks like - It has been cut off for the last 10 years or so.
At the moment I am physically moving the dish - I under it is not advised but I am just trying to find any that shows some signal at all.
Thanks again.
36 volts?? 90% of the FTA receivers out there can't supply that kind of voltage, not without an add on Vbox, I hope you didn't try to hook the receiver up to this motor.
In your settings you have it set to 18V skew ON, set it to H / V for transponder switching, the will allow the correct switching for the transponder you have selected.
And if your not getting a good "S" signal then something may be wrong with the settings for that LNB, or the LNB is not getting DC power.
