Request - advice on best DVB-s2 USB 2.0 box
Tektronix
Laptop Windows 7 64bit ultimate
with ProgDVB s/w & DVB Viewer Pro
80cm dish with
JAEGER SUPERJACK DG-120 DISEQC MOTOR
Yorkshire, UK
Hi all,
I'm after a DVB-s2 USB 2.0 box with the following features:
USB 2.0
DVB-S2 / HD / MPEG-4-/H.264
DiSEqC 1.2
CI Interface
BDA drivers for Windows 7 64bit Media Center support
(which now includes multi tuner DVB-t Freeview and DVB-s Freesat support)
DVB Viewer compatible
I've done some research and found these:
Technisat SkyStar USB 2 HD CI
_http://www.technisat.com/indexdb3d.html?nav=PC_products,en,76-228 - TechniSat SkyStar USB 2 HD CI [4104/3733]
TechnoTrend USB-Box TT-connect S2-3650 CI
_http://www.dvbshop.net/index.php/cat/c473_TechnoTrend.html - TechnoTrend
Could anyone comment on which is best to go for or any good alternatives?
I would like to use the new DVB-S2 USB unit with my DELL XPS M1330 laptop.
Much appreciated
Tek
Moderation note - Please remember to unlink URLs to outside sites.
Tektronix
80cm dish with
Yorkshire, UK
I'm having another go at looking for this item
After 5hrs of searching i'm considering the "anysee E30 S2 Plus".
or
"anysee E7 S2" (not sure what the difference is except for the enclosure?)
Features include:
TV Box for HTPC & Media Center PC
DVB-S2 MPEG-4 H.264
HDTV
Windows 7 both 32bit and 64bit
Windows 7 Media Center / BDA Drivers + Setup pdf instructions
Multi Tuner (more than one anysee should be connected)
Smard Card Slot (CI)
DiSEqC 1.0 & 2.0
USALS
anysee E30 S2 Plus - Satellite (DVB-S/S2), Smart Card Slot.
_http://www.anysee.com/eng/product/anyseeE30S2Plus.php
_www.youtube.com/watch?v=L5cSjTmZy2g
www.youtube.com/watch?v=fB7nF9grqu8]YouTube - Media center on anysee E30 S2plus (dvb-s2)
On the website the downloads include setup procedures for Windows 7 Media Center and it will work with the x64 version apparently.
A loop-out also exists to allow two units to be used as a dual tuner.
To get an idea for the size of the boxes, here are the DVB-t versions:
_www.youtube.com/watch?v=a8T_KhgxOpY
I had a go at this back in May 2010 and got nowhere
Hope this helps. If anyone knows of a better one please add it to this thread.
kim1406
Visit site
pj::
Have you purchased the card or not? Why didn't you consider Technisat SkyStar ? a good brand and can be used for card sharing too.
