Reset Procedures for Various Receivers
Started this thread as it seems to be a fairly common question. If you know the reset procedure for a receiver, please post it here.
This thread is for working resets only, no questions please
Press Menu button and then type in 6787 this will take the receiver back to factory settings.
T24
Info Exec
Reset your Nokia:
Using the remote control, switch off the Mediamaster 9800 S.
The time is shown on the display.
Now press and hold the Program+ button on the Mediamaster 9800 S.
Keep holding the Program+ button and press the Program- button as well.
Keep both pressed until "CUSt" appears on the display.
When you release the two buttons, a message (Pull The Cord) appears on the display.
Remove the power cord from the socket, wait five seconds and then plug it in again.
Echostar 3000. Using the remote press:
Menu 6, 6, 6, red.
john_graydon
Dublin....Ireland
Press Menu Button
Scroll Down to 3 Reset (Factory Reset)
Press ok
Press ok Again
Done.
OK - a reminder to everyone. This thread is for information about receiver resets ONLY. It is NOT for asking questions about receiver software updates. Questions will be removed.
black eagle
Fixed Sats:42E-28E-19E-16E-13E-5E-1W-7W
PC setup Win Vista
Turkey
Hi,For reset Kaon old boards;from STB>press 3 times exit+Remote 1...... For Kaon new boards;from STB>press 3 Times CH+Remote 1 Thanks everyone.
BadWithComputer
The Local Drunkard
30MB ADSL ONO, Spain
32" Internet connected TV
Many Satellite Dishes.
Humax HD Freesat Box
Spain
SilverCrest SL65
Go to system setup in the menu and select factory settings. This will wipe your box and start from the beggining.
Seeing the number of folks who dont seem to understand our rules on this thread - a reminder:
This thread is for information about working receiver resets ONLY.
It is NOT for asking questions about how to reset your receiver or for questions about software updates. Questions of any sort will be removed.
turtonm
SL65/12
UK, Co. Durham
AlexBellisBrown said:
SilverCrest SL65
On a SilverCrest SL65/12 just hold in the power button for 8 - 10 seconds this will reset the unit loosing all user data and settings this also gets round forgotten pin protection.
handasa
satellite
sudan Elobeid
Topfield / 2606 this number will reset the old password
