Reuters WNS Amos 5 @ 17° East
adonis1
Amos 5 @ 17° East
4120R? SR 7200, FEC 3 / 4 DVB-S/QPSK
7.3 db
I don't the reason why , I have stronger singnal with right polarity than left , as boards reports .
-http://www.flysat.com/amos5.php
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Hello adonis1,
these two frequencies (4120 and 4126) are of course right cirkular.
Best Regards
qwer.
adonis1
Thanks qwer
I was thinking , that something was going wrong with my C Band reception
pride21
Sandown Isle of Wight
hi adonis1 i have just got this channel on 4120R ok but mtv seems to be bit weaker is that so.cheers
More channels reported lit up on 17E
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Yep ..got the Reuters feed and MTV base channel t'other day ..
Mtv encrypted of course ..
Time for a blind scan if more channels are 'lit up'
rgds
VS
btw ..MTV was particularly strong around 11:00 AM this morning ...not that there's anything to see of course
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hmmm ...
Looks like the reported new channels on Amos might be bogus ?
ERTU
BBC Arabic
AFN
Non of wich flicker the meter on the F15
..and all of which are clone copies of the channels at 1 West ?
I suspect Onacilas report to flysat might have been a mistake ..
Anyone get these channels ...or has there been a f*** up
rgds
VS
nelson_b
Contributor
hi -
a mistake i think - -- just Reuters - and MTV base for me -- when i looked just now
cheers - nelson.b.
aceb
Prof Tuner 7301 /
Sussex
Just rechecking this one, both the logged transponders are below lock to me but I'm also seeing two other carriers that appear to be on 17E but again just below lock or empty. Could someone could check 3975L and 4042R to see if they are anything of interest? Damn, I need a bigger dish! 'O'-red
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hi Paul ..
MTVbase locks best for me around 11AM ...and is often too week by the time I get home from work ..
I'll check the transponders you list when I get home ..
In work atm ..
rgds
VS
aceb
Prof Tuner 7301 /
Sussex
My day off tomorrow so I'll set the alarm for 10.55 :-rofl2
adonis1
I checked the new frequencies yesterday but without success .
aceb
Prof Tuner 7301 /
Sussex
Going slightly OT onto Ku, Nelson are you still getting Kurdsat on 12393H? Just seen your post so thought I'd try but nothing here. I can't find it listed anywhere so not sure what beam it is on, the Amos site shows three different Ku beams all very close to the UK.
nelson_b
Contributor
hi -
i had forgotten all about that one -- long since - gone from my channel list --
i will try later with the 1.8 and report back -
as you say though nothing listed for k/u at that position now .
cheers --
aceb
Prof Tuner 7301 /
Sussex
Ah, that explains a few things :-ohcrap What I didn't notice on the other forum was the original posting date from 2010 that William resurrected today. :-rofl2
nelson_b
Contributor
hi - aceb -
no - nothing on that old Kurdsat frequency --
cant realy blindscan properly around 17 east -- some overspill from 16 degrees
and some- thing i.v never noticed before - with my dish - i get a secondary reflection from 19 east - around 17 degrees -- on k/u band
if i track west from a strong 19 east channel i lose the signal briefly - then pick it up again but very weak- only just above lock , most odd -
cheers --
edit --- l.o.l. - there,s an old post about the kurdsat frequency on here too --
http://www.satellites.co.uk/forums/transponders-channels/174000-amos-5i-17-0east.html
Another change reported on 17E:
Doordarshan channels on
4131 R
DVB-S2/8PSK
5530 3/4
aceb
Prof Tuner 7301 /
Sussex
This one is still out of reach for me but I blindscanned it this morning using EBS with the trickAPSK option checked and locked a number of transponders as follows
5=3803,V,4293,34,32APSK
6=3821,H,4750,34,32APSK
7=3880,V,2500,34,32APSK
8=3891,H,6877,23,8PSK
9=3955,H,10970,56,16APSK
10=3957,V,15000,34,32APSK
11=4003,H,3208,45,16APSK
12=4049,V,2500,34,32APSK
13=4094,V,15000,23,16APSK
The one I'm interested in is 3891L as it's the only one I can lock when scanning in Crazy or Dream, how does it compare in strength to the four active video transponders, just wondering how far below threshhold they are with me?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hi Paul..
Not tried to lock data transponders ...but you should be able to lock the Reuters feed ...which isn't always active ...and possibly MTVbase ...which is a constant ..
But both are Time Of Day dependent ..to some extent ..
Try again at various time intervals ..
If memory serves ..evening was best for me.
..or maybe its just the F15 outperforming again ..though Nelson has also locked 'em
good luck m8
VS
nelson_b
Contributor
Vipersan said:
Hi Paul..
good luck m8
VS
hi aceb
all i can pick up here this evening is M.t.v. base -
its a very weak signal though - slipping in and out of lock
regards --
