nokevin
- Mar 27, 2004
- Age
- 61
- yellow import
- South, Very south
Hi all,
Can I use the RF out on the back of the Panasonic digibox to connect to more than 1 TV? My main TV is plugged in to digibox via the scart cable, behind the TV on the wall is the socket for the incoming TV antenna that is on the roof of our block, we don’t use it cause it the local Spanish channels, it comes in the house behind the TV and then goes in a small splitter thingy ?? And then goes to all the other rooms in the house, if I disconnect the incoming and connect the RF out that is on the back of the digibox, would that work ok or would it shag the box cause it only designed to run 1 TV
Steve
Steve
