Samsung DSR9500 - Not recognizing Funcard
jchurch
Hi ,
I`ve just become a member on the forum and have just acquired
a USB Infinity programmer with Fun card 5.
I was hoping that some of you clever guys out there could help me out
with a problem I`ve got.
I have a Samsung 9500 VIA CI which I`ve patched with software version 118 giving the 5 in 1 patch.
I`ve managed to program the funcard OK to get ABSAT channels using the file `2ndfun5in1v1.20_Jula_AU_18.06.2003.`
After unzipping , this comes with a flash.hex file ,
`eprom_integral.hex` file and a `eprom_by_jula.hex` file.
All these load into the funcard5 via the Infinity USB programmer
with no problem. After I insert the card in the Samsung9500 it recognises the card as a Mediaguard card OK.
My problem is when I try using a different 6in1 file.
I downloaded the file off Phillsfiles.com. It is called
`davem_fun_6in1_030703.zip`.
After unzipping it it and reading the readme.txt it looked like the
files should work with a Samsung9500.
The files that I loaded onto the funcard5 were :
`flash_6in1_v4.3.hex` into the flash area of the card.
`eeprom_H_030703.hex` into the external eprom area of the card
I left the internal eeprom area blank.
Unfortunately the Samsung does not recognize the card and when I go into
the card information menu on the Samsung whereas it said mediaguard on the `2ndfun5in1v1.20_Jula_AU_18.06.2003.` files it now says
`no card` with the davem_fun_6in1_030703 files
Does anybody know why the samsung is not recognising the card.
Do I need a different type of card - eg Gold or silver ?
Do I need a different CAM.Eg Irdeto - as I understand that a lot of the
5 in 1 files operate via irdeto somehow.
I was under the impression that the 5in1 patch allowed the Samsung to
recognise : Viaaccess ,conax , Seca Mediaguard , Nagro.
I`m not sure if it does the irdeto. Does anybody know ?
Any help would be most appreciated.
Its all a bit confusing at the moment but I hope to get my head around it in the next couple of weeks.
Thanks in advance for any help.
Although I have no experience with the patched Sammy, is there a CAM menu in which you can select different modes for the CAM, it certainly sounds as if you have used the correct procedure with the Dave M files, but may also be worth trying the Xamuh files, they are set up specifically for the Sammy.
turny
msn.co.uk
tyne and wear
hi jchurch
the answer to your question has already been answered look at receiver upgrades and a post by steve102 remember reading past posts can be a hive of information some of it good some of it not so good.
jchurch
Thanks Rolfw / Turny
OK thanks for the information. Looks like I need an Irdeto CAM for these type of files then.
mehdi13523693
i have samsung9500 that cant read card and open the scramble chanales
how can i get a software for opening the scramble chanal without card or with card?
T24
Info Exec
Which samsung 9500 do you have?? VIACI,AY,Ci.........?
T24
Info Exec
Yes,your samsung can decrypt Viaccess channels.if your samsung is patched it can
decrypt alot of channels.(load your receiver with samsung EMU) or load a silver card
with bbaio files (6in1) insert the card into the embedded cam.
Ps-insert the card into the embedded cam correctly,the chip downward..
(power OFF/ON)
Load the latest via..files works fine on fun card.
Good luck
Good luck
safad
You can use the funcard with the Sidd-9 files you can found this files in the tonys duo site
T24
Info Exec
Bb aio files (6in1) on Silver card works much better than sidfun9.
ardalanlp
i want software for samsung 9500 VIA CI
and i want watching the nagra channel & irdeto channel
what can i do?
thanks a lot
T24
Info Exec
Do you have a patched VIACI?
check the hardware,software,loader
Menu>system setup>system information.
mnadeem
Visit site
hi i have same problem , the fun card is not recognizing with the receiver , but my receiver is not samsung as every one talking , It is redix dt-43 s vaci
software version DT-43S V1.0.00
firmware V1.2.1-1614SA
Terminal serial number 34-1-0001469
Viaccess version 1.1 R 484
terminal application 1000.121
O-no
so if any one can tell me what should i do, greatful to him :D
hormoz
reza121 said:
pls help for upgrade eurostar model 9700f
I have the same problem, If you find the answer please say it to me.
Thanks,
Hormoz
