Samsung + fun card
bremze
Dreambox 500 with Hydra image
Hi all!
I know that almost all of you are great specialists, I hope some could help me with my situation.
I have DSR samsung 9500AX. Also I have funcard and USB Infinity programmer. And also I have internet with lots of files that I can write to my funcard. :)
That's all I have at the moment.
Yesterday I wrote some Xin1 files to that card and could watch v|access1 channels. Ok, that's cool but what about the channels with some other encryption, like s*y italia, taqu|la etc.?
If I get the information right, I somehow have to make better my DSR with some kind of patch, right? Can I do it with my samsung 9500AX?
As I understand for that I need a computer with COM cable, right? Where to get the program with an instruction how to patch a DSR and not to kill it? :)
can someone please help me?
Thanks!
bremze
yes, and additional -
I also have 1 GoldCard and one Silvercard, if this can help somehow...
Neither of those packages are available at the moment, did you try TV Cabo on 30W?
bremze
No I didn't, I am too lazy to go out and turn my dish somewhere :)
I have signal from 3 satellites: astra, hotbird, sirius. I didn't get programmes even from p0lsat, but I have red that it can be watched without subscription.
But what if I patch my samsung? Really, no other packages, only V|access1???
Razor
Retired Mod
Ireland
Goldcard= (Via1, Seca1, Irdeto files are still available for those), Silvercard (Via1 and Conax-based xin1 BB AIO), Funcard (for Irdeto-based Xin1 and Nagra AU),
The Sammy is a do all box, when patched, if I had one I would set aside a day to to some reading. Go to Nobley's section here and click on some of the other boards. Toe's and Dudez both have big Sammy sections. Also go here www.lyngsat.com and see what channels use what encryptions.
bremze
Razor said:
Goldcard= (Via1, S*ca1, Irdeto files are still available for those), Silvercard (Via1 and Conax-based xin1 BB AIO), Funcard (for Irdeto-based Xin1 and Nagra AU),
So, if I understand right, with my funcard I can watch ORF, for example. Or those Italian channels (RAI etc.) also when encrypted. I tried many files, latest versions named Xin1, nothing worked. Only Via1... Wrong files?
Razor
Retired Mod
Ireland
Start off with just pure files first...i.e. via1 only or S1 only try not to mix encryptions on the same card. When you master these, then move on to 6in1 or Xin1 type files.
