siroscar
- Jun 30, 2021
- Age
- 44
- none
- Portugal
Hi!
I would like to try having a satellite dish but I don't understand much of the subject and I have some doubts about the process, basically the necessary equipment and what is needed to do, if you can give some help it would be nice!
From what I understand with the dish it is possible to directly get the feeds from the satellite and then the receiver receives the feed and transmits it on TV.
But then I'm a little doubtful in terms of equipment that is necessary to buy for this.
Some questions I have are:
- we need to buy a satellite dish, but how big should it be? I've seen them with 60, 80 cm and over 1 meter, I also saw some dishes with an engine system
- Then in terms of receivers I saw the amiko 8155hd line ccam seem, do you know if it works for this goal?
- And for what I understand the feeds are encoded, does the receiver (for example the amiko or another) automatically decode the feeds or is something else needed?
- Also do you know if its necessary to buy a satellite card for PC? Or is it just the satellite dish and the receiver?
Thanks!
Thanks!
