Sat system
zbiba
Echostar DSB-800-2CI
Pentium 4 +
will be using laptop with card reader+program
malta
I have a sat. system Echostar DSB-800-2CI, but I got fed up bying cards that expired after no time at all. I have a Magic Module PCMCIA and Seca 1.03 card which has a goldish colour. I have not used them for about 2 years and I use the system without them. Obviously missing a lot of channels.
I have a card read/write in my laptop. Can anybody tell me wether these cards can be updated online. I apologise, I know nothing about this so please help.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
I'm sorry to say that in its current format there is nothing you can open with the magic module that I am aware of. Time to save up like me
zbiba
Pentium 4 +
malta
thanks for the reply but can I at least programme this card or shall I throw it away? If so what do you suggest I should buy?
Topper
Well not being particulary up to speed on this subject these days I don't feel qualified to give that kind of advice. The problem is that support comes and goes with both cards and cams. The best supported cam appears to be the Dragon/Trex but you will probably need to buy a programmer as well and it all adds up. My advice would be to decide exactly what it is you want to watch then take it from there.
zbiba
Pentium 4 +
malta
Thanks a lot for your help.
