Sat TV distribution 3 rooms
Wild Thing
echostar 3000
Northern Ireland
Hi guys
Hope you can help and advise what I need to get for distribution.
Basically I have a static caravan that I want to set up a sky reciever in the lounge area and distribute it down to two end bedrooms. Nothing fancy like multiroom just the ability to watch sky fed from the receiver in the lounge to the bedrooms and be able to change channel from bedroom. I understand all tvs will see same channel but this is not a problem as only one TV will be watched at a time.
Hope this makes sense.
satelliteman
Hi and welcome,
A simple 2 way IR distribution amplifier fed from the RF2 port of the digibox.
_http://www.globalinvacom.com/products/f140.php
leez
tm 9100 tm 1500 ci dm box 600 1 m dish polar mount 12 inc acuator v box 2 cas 3 dragon diablo gamma
england
you will need a small amp 1 input 2 output with digital bypass built in for magic eyes .. this will be fed from the rf 2output of reciever , the 2 outputs will feed other tvs for which will go into the outputs of the amp ... after that its just a job of tuning in tvs and fitting magic eyes lol ...also make sure the line voltage is turned on in the sky menus ...services .. system setup ...0 1 select ..4 rf outlets then turn on the setting to on for line power and save settings good luck ..
Wild Thing
echostar 3000
Northern Ireland
Thanks guys. Had a look at the F120 which is 1 input x 2 output which is what I need. Just one more quick question. The F120 has F connectors. is it OK for the patch leads to run f connectors at one end and standard aerial plugs at the other end for the tv signal in.
leez
england
firstly soz satellite man , you beat me to it m8 lol ... and yes it ok to have f connectors and rf connectors lol .. it will not make any difference .. depending if you want to use tv link , you can get some that have f connectors on input of tv link ..it all depends what you buy . whether it rf or f dosen t really matter ..
satelliteman
No problem at all :)
There are a range of amplifiers available with IR pass either mains or line powered.
Wild Thing
echostar 3000
Northern Ireland
Thank you both very much for your prompt replies
