- Sep 11, 2008
- 57E to 58W, C-band and Ku, DVB-S2, 4:2:2 and blindscan.
- 38.5ºN, 0.5ºW
Yes, it's just simple trigonometry. Pick a location for the beam centre. work out the distance from that location to your location (or to the location of the pixel on the map). Work out distance of beam centre to satellite. Work out distance of your location to satellite. That gives the lengths of the 3 sides of the triangle. From that you can work out the angles.Can you reveal how you've calculated that ? I'd like to play a bit with the formula.
If you want a more in depth answer (or to see the maths) we can start another thread so we don't drag this one off track.
That's not giving you the distance the beam moved over the earth when the satellite changes its attitude i think.
Anyways to be precise you'd need to use spherical trigonometry, which i have completely removed from my mind. When using an approximation with normal trigonometry one would get the minimal distance only. Ie using 0.15 degrees on the satellite end, using the distance from me to the satellite as the adjacent and hypotenuse of the triangle. that would give me the opposite (ie the resulting distance of the pointing error on earth) as d * tan 0.15 with d=
38932. That gives me about: 101km. Which is near enough the expected value to make it plausible.
But you are right, probably the wrong thread. Let's look at transponders again. ;)
Like I said you can't give this a numeric value. For locations where the satellite is near the horizon the distance is huge. And I don't see why you are trying to complicate things talking about spheres. Triangles have 3 straight sides. If you know the length of each side you've got the angles too. No spheres involved.That's not giving you the distance the beam moved over the earth when the satellite changes its attitude i think.
Give me a location and I'll draw the 0.15 outline.
Because the earth is a sphere and we measure distances on the surface of the earth. Spheres involved. And i can give it a numarical value. i know one angle (0.15 degrees attitude change) and one side of the triangle, ie the distance from me to the satellite. And i want to have the distance the beam moves on earth when the satellite rotates by 0.15 degrees around the z axis, ie the axis through the solar paddels. I think you are talking about a completely different problem.
We are just measuring the distance between two points in space. That the media between those two points might be solid rock is irrelevant to the distance between the two.Because the earth is a sphere and we measure distances on the surface of the earth. Spheres involved. And i can give it a numarical value. i know one angle (0.15 degrees attitude change) and one side of the triangle, ie the distance from me to the satellite. And i want to have the distance the beam moves on earth when the satellite rotates by 0.15 degrees around the z axis, ie the axis through the solar paddels. I think you are talking about a completely different problem.
As for how far the beam moves on the planet's surface is based on the location on the planet and the elevation of the satellite. And it is not circular and varies from one location to another. Look at the maps attached. Both are the satellite swinging the beam in a 0.15º perfect circle, one over Ankara, and the other over Dublin (with the satellite geostationary at 28.2E). Note that even though the satellite is moved in a perfect circle what is seen on the ground is far from circular. And certainly not a fixed distance.
