Satellite Motor
Marcas
Fracarro penta 85cm dish, motek motor and Technomate 5200D receiver
Belfast
I'm thinking about adding a motor to my satellite system. The most commonly available seem to be made by Motec Technomate and Foretec. Are they much the same or are some better than others?
Out of those three, the only company to make motors is as far as I know Moteck, the others are re-badged. I have had very few problems with the many Motecks installed over the past few years.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
The Fortecs are reboxed STABs.
Currently got an HH90 with a Triax110cm on it, it hasn't fallen apart yet.:-rofl2
The Technomate motors are manufactured by Moteck I believe.
HB13DISH
Retired Mod
Middle East - Israel
I enquired about Technomate motor and it doesn't look like a Moteck made, but apparently by unknown motor manufacturer and they just put the Technomate name on it.
Just like Dark Motor.
http://www.satellites.co.uk/satellite/digital-systems/123341-got-my-new-system.html
Post #10 thinks it a Moteck, but where is the proof?
Marcas
Belfast
Thanks for your thoughts. It would appear that the Motek is the safest option
satelliteman
Do check the hardware limits on it b4 you you get it up, I found the last one were set to 50e ~ 50W ....well within receivable satellite but well it's worth a check and adjustment.......:D
good solid reliable motor
