Pete-
- Mar 7, 2009
- Age
- 46
- New setup, 1 standard sky dish, 4 port LNB and 1 free view aerial
- Staffordshire
Hi All
Some great posts here! I need to pick your massive brains. Just redone my place top to bottom. Got the following in:
1 normal Sky dish on end of house with 4 port LNB.
Taken 4 coaxial cables (CT100 i think) from LNB to plant room.
Got new digitial aerial on end of house with a CT100 (i think cable) going back to plant room.
From Plant room i have run in 2 coaxial cables to each room terminating to a single 1 gang face plate, with a F-type termination on cable 1 and one normal aerial push connection termination on cable 2.
My thoughts were to send Sky to the f-type termination and freeview to the other.
Questions:
1. The run from the end of house to plant room is about 21meters, will i need a maskhead booster of some kind for the digital aerial and can someone recomend one?
2. Whats the best bit of kit to distribute the free view round the house?
3. I was planning to have separate sky recievers in up to 4 rooms (as i only have a 4 port LN, is that the best way to go? Or welcome any other thoughts?
The plant room has power and room for distribution kit.
The maximum run from plant room to other rooms is again about 25 meters.
Thanks Pete
Questions:
Thanks Pete
