Set up C band Dish .
hafid59
180 cm Fortec star , Goldvision
France
Bonjours j'ai une parabole 1.80 c Band je n'arrive pas a capter Hotbird ni Nilesat , Aider moi svp pour bien la régler . je l'utilise avec un LNB 0.2 DB de Mti est ce qu'il faut changer de LNB . Merci
Hello,
I have a 180cm Fortec star dish can someone help me to set it up correctly
i use a MTI Supreme Line LNB single 0,2 dB , I dont have any signal 0 % . I live in France .
i have a question can I receive Hotbird with this Dish . I bought it to receive Nilesat 7 west .
You shouldnt have any problem with Hotbird on a 1.8m dish - in France a 50cm should be plenty!
guest poster
registered
Is that LNB an LNBf or C120 with feed horn. (it should be the C120 and the feed horn set to the f/d ratio of the dish)
Also, those dishes are difficult to build accurately.. if both are wrong you have a very big 'little' dish.
And ....the dishes are not strong so avoid strong wind exposure… or add strengthening.
hafid59
France
thanks for your replays .
pedro2000uk i don't know Is that LNB an LNBf or C120
link to the lnb _http://cgi.ebay.fr/MTI-Supreme-Line-AP8-XT2EBL-2dB-Single-Universal-LNB_W0QQitemZ110329437271QQcmdZViewItemQQptZUK_ConEle_SatCableFreeview_RL?hash=item110329437271
guest poster
registered
That's an LNBf .. used on offset dishes.
The dish you have is a prime focus, well I think it is... is it ?
has it 6 sections to bolt together and 3 arms that hold the lnb in the middle?
hafid59
France
yes my dish is a prime focus .
what sort of Lnb shoud I use ?
It is a Jonsa dish though :-rofl2
BombedOne
Republic of Georgia
Well, 180cm fortec star prime focus dish is solid one, no segments (at least, such model is sold here).
You will need C120 flange LNB and feedhorn (check attached picture).
General plain LNB will also work (like one you have already), just 180cm dish will work as 120cm one, if not worse. But it will be still enough for Hotbird.
