Setting Default Channel on a multiple Sky + Setup
iwelsh
SMATV using a combination of 11 Sky + and Freeview Boxes. Each box broadcasts a single channel which is then distrubuted to TVs on campus
Grantham, Lincs, UK
We have 11 SK+ boxes each tuned to a single channel. The feeds from these boxes and some other Freeview boxes are then distributed arround the campus.
Each Sky+ box has been programmed to start-up on a particular channel. How can we change this 'default' channel?
Thanks in advance.
Regards
Ian
Harlaxton College
satelliteman
Welcome,
You require to re-programme the SMC's ( satellite master Controllers ).
As it's a SMATV system, I recommend you get a professional in to do this. I've done plenty but it's too time consuming to explain. Also with Sky+ it would be a good idea to make sure the SMC's are Version 2.
.........assuming you have professional SMC's for your box resets. Won't reset the freeview receivers.
Satman :)
iwelsh
Grantham, Lincs, UK
Thanks for the info.
Yes we have SMCs (not sure which version). I'll contact our supplier. I thought it might be something we could do via the Sky+ box.
Regards
Ian
It is a fairly straightforward process to set the channels to an alternative, but is done on the SMC module.
satelliteman
Lets hope their not pin locked :D
satelliteman
Attached file.
SM :)
leon roual
8 sky recivers, multi switch, 2x smc,
cumbria uk
I work for my father installing tv aerials & sky. my father is off ill & i need infomation on how to set sky master controllers as I have not learned about this yet.
I understand how to connect them & understand how they work, im just not sure if there is anything I need to do to with the smc itself.
kind regards
leon roual
