Setting up a Motor what angle elevation to set to?
misterminibus
Lancashire
Kodi
Lancashire
davie said:
Can someone please help me?
Davie.
I am in the same situation as you davie, I have been on heavens-above and my location I think is 53.5900N, 2.2950W Bury Manchsester so How do I find out what angle elevation to set to?? very confusing
Is this an H-H motor like either of these?
H
Happy-Buddah
In two of the motor handbooks that I have they indicate that if latitude is 53* then elevation is 37*.
Whereas the Rotor Sat HH100-HH120 handbook indicates the elevation of the motor is set to your latitude.
H-B
misterminibus
Lancashire
Kodi
Lancashire
its a small pic but mine looks like the second motor.
misterminibus
Lancashire
Kodi
Lancashire
i shall try 37 thanx... I have my dish on a pole in the back garden and if i face astra 2 i get 10 % signal if i turn the dish 360 deg it doesn't alter.
I have tried the dish in my sky digibox and i get the same outcome no signal is the lnb dead? is there a way i can test it ?
my echostar works fine with my minidish in so both receivers work.
georgia_grrl
i had a nightmare with following the manual for my motor, i recommend you set the motor to whatever the manual states, then move the dish up and down till you get a signal, then see if you can find anything else (it worked for me)
vinny048
What is the make of your motor?
misterminibus
Lancashire
Kodi
Lancashire
I would love to but i bought it from ebay and i have no manual has anyone got one they can scan and send me via email? (please) :)
misterminibus
Lancashire
Kodi
Lancashire
Geotrak sg99 gold silent H-H like the one on the right in the picture above.
misterminibus
Lancashire
Kodi
Lancashire
Has anyone got the instructions to set up this motor direct into a receiver (echostar AD3000IP) or know of a link where i can view them??
(pretty please)
Moved your post into this thread, please try and keep it together, otherwise it gets very messy.
You say that your motor is a 99, but indicate that it looks like the right hand picture, that one is a 128. Does the dish mount onto an armature, or does the motor bolt straight onto the back of the dish?
misterminibus
Lancashire
Kodi
Lancashire
it bolts onto an arm i tried to email u a pic but its not allowed is there a way i can show u the pic?
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
Use the attachment option at the bottom of the Reply form...
Manage attachments then point to the file (best if you use a jpeg) and upload it here.
misterminibus
Lancashire
Kodi
Lancashire
Happy-Buddah said:
HI
Is this the one?
H-B
Oh gawd he's done a runner!;)
surelooks like it.
I think i have managed to send the pic as an attacthment have a look im doing it today so any instructions from the setup of the motor manual would be welcome thanx...
I seem to remember that the instructions for the motor have a cut out template to indicate the elevation angle, well at least on the DiseqC version they do.
misterminibus
Lancashire
Kodi
Lancashire
My problem really is, if i say the angle is 37 deg, with the dish/motor being already used the motor has turned round to a satellite then powered down and sent to me so what angle do i set the motor to is it 0 deg ??then bolt the dish to it facing and i am only quoting what i have been informed facing thor ??and then use the software of the receiver to locate the other sats?,
Is that clear enough to understand? cos its confusing me and i know what i mean lol.(laughing out loud)
Yes, set the motor to zero degrees, then bolt on the dish facing perfectly straight and find 1W by moving the motor on the mast and the dish elevation.
misterminibus
Lancashire
Kodi
Lancashire
so I set the motor to 0* bolt the dish on facing straight so when the motor is powered it can move 90* in either direction, im running it through an echostar ad3000ip so once I have completed the above the rest ie the lining up of the dish to 1* west is done via the remote control and the receiver is that right?
ps thanx for taking the time to help a novice :)
