Help Required Setting up CrazyScan
kingkad
3.8m Prodelin Offset.
London
Hi Guys
I have a DVBSky S952 setup with 2 fixed dishes (10eKu and 68.5eC)
Im trying to setup CrazyScan as I want to get more detailed signal levels for the 68.5e setup.
I've tried downloading and putting the correct files in the correct places but with no luck
Anyone able to give an idiots guide or help via Teamviewer.
What message(s) are you getting when executing Crazyscan, if any?
Do you have the required QT DLLs in Crazyscan's directory?
kingkad
London
Screenshot here
You're using the DVB-T/C version of Crazyscan (Crazyscan2).
Use the DVB-S/S2 version (without the '2')
kingkad
London
Thanks Chris!
So now have v1.0.2.119 working.
Below is scan, not sure what to make of it
I see others posting what looks like a scatter graph on their screenshots, whats that?
Just looking to see what can be done to improve signal on this 3.8m
Archive-8
Thanks Chris!
Once it has produced the graph, you need to blind scan.
If you use the template (crs) files check the diseqc settings :-)
kingkad
London
More progress
Oddly nowhere near as many transponder as I got on the technomate when I lasted scanned a few weeks back.
kingkad
London
What am I meant to do with:
TSReader_BDASource_DVBSky_S.dll
and
Streamreader .dll and .ini
The machine is on teamviewer if anyone wants to play
kingkad
London
Just had a look, the sym rates look completely off to lyngsat?
kingkad
London
Also, is there an option for LNB power in crazyscan?
kingkad
London
How do i get this screen?
tempo
47.5N, 42.2E / Russia
DVBSky S952 card based on Montage DS3000 chipset with specific closed-source blindscan algorithm. Unfortunately, constellation isn't possible for this chipset. Also carrier search require some frequency band (between min and max freq for search). As far as I remember, by this reason "Carrier search and constellation" dialog window blocked for all Montage-based devices. It would be useless otherwise.
Sorry, but for full features of CrazyScan program you need device based on another chipset.
kingkad
London
thanks, that helps, was wondering why mine looked different.
so whats the most well supported/ best reviewed card? need dual tuner and sensitive as i'm fringe.
Ratchet
Falkirk
TM 5402(M2), TBS 6983, Sky+ HD, Stab USALS HH100, Faval 1M, Triax TD54, Hauppauge HD PVR
Falkirk
Archive-8
The TBS 6983 is your best bet. There is an established thread for this card in the link below. It's around the £200 mark from various suppliers including some site sponsors no doubt.
https://www.satellites.co.uk/forums/threads/tbs-card-6983.162419/
I can highly recommend the tbs6983, it's a twin tuner card. It also has the internal power adapter. But it's around the £200 mark.
Mine came for red apple digital when I had a problem with my old card they were very helpful.
