shefield derby
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
cheshire,algeria
12.5w 11189-H-5632
john_graydon
Dublin....Ireland
Think only mods & admin can do it, cant remember what tools you have but its in the Edit/ Go advance one.
frund
triax 1.1 tm 1500ci+ dm patch. Moteck 2100. Intel 4300 based pc . LG7500. 32" lcd
Wales. UK.
I have not turned to 12.5. Is it mostly up/down link communications and can I get it here in deepest Wales. thanks
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
frund,
your right, but they do use feeds there, i would think youd get 12.5w easy, and if you keep scanning when feeds are on you'll build up a list where by you can go feed hunting yourself
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
never mind then, hopefully when they read a post with title footbal feed they will look and alter occordingly
frund
Wales. UK.
Thanks for that Bronking, I will switch on and have a look later. This feed hunting thing is a bit new to me and I'm sure I miss a lot by not understanding where things are and what I'm supposed to look for. I have learned a hell of a lot from the members here, dish setup etc, where the footy is on like Becham's lot tonight tequilla1 30w.
