silver card+gemini se programmer
fabio1
hello everyone.. i am a new user and have the force1189 with a silver card that doesnt work no more...i have now bought a gryptik gemini se programmer but do not remotely nkow where to start ..can anybody be kind enough to tell me how i can proram this card with my programmer please....:confused
First thing you need to find is the file, look for a DS9 file.
Then you open up the programmer software and set it to silver card, some software will self identify the card for you.
Then you load the Pic file and the Eeprom file and press program. Some software does this differently, which programming software are you using?
fabio1
thanks so much for your reply...i downloaded the cardmaster 2 software from the tps site..is this ok?
Yes, providing it works with your programmer. There may well be a tutorial for that software on www.duwgati.com
fabio1
thanks rolf...ill try that first...do i just do a search for ds9 files on google?
fabio1
don't understand that...sorry quite new to all this....:confused
