silvercrest sl65 help
jobtroter
satellite
uk
I've got a silvercrest sl65, i used a program, i upgraded, i used a null cable 9 pin.In the key editor,i enable cas system.
After i put the keys.I could see the channels ,but after 1 minute the channels gone blanck .Please can anyone help me . maybe i put the keys in the wrong places.Please can anyone help? i am not sure how to add on the keys on the key editor.
jobtroter
satellite
uk
I got silvercrest sl65 and I can not make work when i put the keys on ,please can anyone help?I am using satellite hotbird 13 and astra 19.
WHICH channels on which satellite?? We are not mind readers, and if you dont give sufficient information you wont get an answer.
jobtroter
satellite
uk
Please, I need someone to tell me how to add keys on silvercrest sl65 and if there is new keys?I am using satellite astra19 and hotbird 13
Try answering post # 3 first - we cant help you without that information!.
jobtroter
satellite
uk
the satellite are hotbird 13 degrees ,astra 19 degrees
thanks
Mick21367
Mick21367
A cheap 'n' nasty Silvercrest and an old (but good) TM1000D. 28, 19, 16 and 30W
You could have a long wait for an answer if you don't let us know what channels you're trying to watch!:) Anyway, I'm fairly sure that there isn't much on either satellite you can view without updating the keys at least twice a day, if not more.
You'll also have to let us know what version of the SL65 you have - there are a lot of different firmwares for different hardware revisions.;)
jobtroter
satellite
uk
thank you for answering my question.The version is sl65a.I would like to know if i update the stb will help?
Yorks
Mentally unstable.
Pretend to know what I'm doing. Only the clever ones rumble me.
S. Yorks
AFAIK there is no later update. You need to update manually via remote.
But as several other people have already said, if you don't say which channels you are referring to, it is impossible to advise you on whether you can receive them or not.
gdulli2
silvercrest sl6/12
manchester
hello everyone i am gdulli2 i am new in here, i was jst reading through wat other people said about the Silvercrest sl65. i have a question i need to unclock the MTV and french channels such as M6, RTL9 i have a digital satellite receiver Silvercrst sl65/12 i dont know how to unclock the channel and how to enter the keys to unlock the channel please help thanks
pgh13
Midlands UK
Hi and welcome. This is an old thread and most of the channels have recently changed encryption and are now secure, so; sorry but you are out of luck although some French channels are still broadcast in analogue if you can point your dish to 5W and can pick up an analogue receiver for pennies at a car boot.
gdulli2
silvercrest sl6/12
manchester
ok
do you know if a new firmware is available for the silvercrest sl65/12 box and howto patch it thanks again
gdulli2 said:
ok
As stated, very little is now open anyway - DigiTV perhaps, but that will be secure soon.
There's no point in searching further as there is nothing to be gained.
