Silvercrest sl65 upgrade
BadWithComputer
The Local Drunkard
30MB ADSL ONO, Spain
32" Internet connected TV
Many Satellite Dishes.
Humax HD Freesat Box
Spain
The Silvercrest sl65 upgrade has a funcion where is you are on astra 19´, you can scan for updates. Does anybody know the frequency for the updates?
misterminibus
Lancashire
Kodi
Lancashire
If you have a flash on it will just go to the latest software, there is a factory reset on it but it will use old software, or turn the power off at the back turn the switch bacl on keeping ch+ and ch- on the front pressed and follow the instructions, this is an old post but if you still need to do this I may be able to help
