Sky + HD input 1 signal fault
A McPhee
sky + HD
Scotland
I am getting the following fault on my Sky recently and was advised to check connections at back of box. I renewed one termination and problem was solved on relevant channel (skysports 1) but now the faults present on another channel (skysports 2). I spoke to Sky who as usual tried to send an engineer out at a high cost which i declined. Has anyone got any advice or ideas? The majority of channels work ok but a few have this input fault present. Below shows text on the screen when faulty-
Input 1 Signal strength - zero
Input 1 Signal quality-zero
Input 1 lock indicator- not locked
Input 1 Network ID/Transport stream- null
Welcome to the Forum.
How old is the box?
What make/model is it?
Has your dish been exposed to high winds, torrential rain etc. of late? (I can guess the answer to that!)
A McPhee
sky + HD
Scotland
Box is about 6 months old. Yeh it sure has, and seemed to happen coincidentally when i replaced old box. The screen would flicker then lose signal. When i renewed the cable connection it sorted this fault but still still cant view certain channels as says Satellite signal unavail.
Appreciate your reply
Retired Mod
www.timo.me.uk
How is signal input 2? I assume this is OK? Perhaps try switching the two LNB connections over at the back of the box and see if the problem changes to input 2.
A McPhee
sky + HD
Scotland
Signal 2 is good. Switched over cables and still the same
That would indicate a problem with the box.
Hmm. If I read Post 3 correctly, along with the other info, I wonder if Sky have fobbed you off with one of their notorious "refurbished" boxes; aka duff ones removed from other clients and simply re-issued.
Ghostleader
Glasgow,ish!
It the o.p. is out of contract I'd just cancel, that will get you a new box every time in my personal experience.
Sent from my T5 using Tapatalk
