sky italia prepaid
teide_ian
Home-Amstrad Sky Digi-box on 60cm dish. Bar - Pace Sky English Digi-box and Grundig Sky Eire Digi-box linked to a 2.4m Channel master dish with a single dual output LNB. Digibox for ART network on 90cm dish. Digibox for Digitalalb subscription. Di
Canary Islands
Just looking on internet and have seen prepaid sky italy 6 months card for around £100 for a sd card not hd.
Is this correct as normally these cards are usually around £1200 is it an old encryption card that only works in certain boxes? as i would be using a dm 500.
Thanks in advance.
Well do you have a link of some sort (disabled it in the normal way, of course)?
teide_ian
Canary Islands
Sorry tivu dont understand your reply?
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Tivu is asking for the link but of a disabled type for example _www.google.com, which is not active
You said you'd found this Card on "the Internet"
'tis a big place, the Internet.
Can you help us out by telling us where on the Internet?
(By Posting a URL link, in the manner illustrated by Topper)
€43 for 5 months?
Ebay item 130493070552
(the listing has finished but it shows they are available)
teide_ian
Canary Islands
Sorry not sure what it was meaning, it is fleabay Item number: 270721353861
teide_ian
Canary Islands
After a bit more fishing they seem to be nds2 cards is this a problem and will they work in a dreambox?
A nonymous
As far as i know they work fine with OSCAM, however updating the card may be the issue that you may need a Sky Italia receiver for. Just look at ebay.it. Sky Italia receivers usually go for around £35 to £50 inc postage to the UK.
Just make sure the seller posts to the UK before bidding.
Nano
teide_ian
Canary Islands
Thanks nano so no issue with cards being nds2 as i thought all sky italy where nds3 not sure though?
As you say if needs updating will buy a sky italy box is there any news on maybe nds2 not being used anymore as in only being nds3?
Thanks in advance.
007.4
STBs = Ultimo4K, VUDUO2, VuSolo2, Alien2, AzBox HD Elite, ET8000:
Dishes = 180cm PF, 80cm offset, 60cm offset, Sky mini:
LNBs c120 for PF dish = Ku-Band White Smart Titanium (modified to c120)
and for C-Band Titanium C1W-PLL
I asked the seller if the CAID was 0919, 093B or 09CD (to determine the card version).
His reply was "I not understand".
Perhaps someone can tell us, what version these pre-paid cards are?
Pipino?
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
hi m8,i´m not sure but what strikes me , is the sell of the card without the box !!! normaly all italian subs comes paired (card/box) ,i would say its a mixed up bunch of cards ..i would ask the seller to post front/back fotos of the cards including the 4/5 first digits to determin the version,,may be they are special for Italian DTT ???in that case the version must be 09CD
