SKY +, Quad LNB, freestat, How ???
fozzy9876
SKY +
S. Yorks
Hi Guys,
Newbie so please bear with me.
I have SKY +, so im assuming I have a Quad LNB. I want freestat in the bedroom because digital reception in our area is crap.
Ive done a fair bit of digging in the forum and believe it is straight forward enough to connect a spare port of LNB via digital cabling to a second free stat box but cannot find a detailed describtion of how to do this (im a dumb ass, I do need one !)
Ok so I can buy a regualr sky box from ebay, found some digital cabling but what connectors do I need. Also do I need to activate the box?
Does anyone know if a straght forward guide to this exists? I think I could get sky out to install multi room then cancle after the first month. But would be paying £100 + to do this. :-Nooo
Any help really appreciated, Muchos gracias, Fozz :)
All you need is the appropriate length of satellite grade cable and two F connectors, you can get both from places like B&Q.
This Guide is for crimp connectors, but the method is the same for screw on type F connectors.
PS. why not just buy a Freesat receiver from one of the forum supporting advertisers. :)
fozzy9876
SKY +
S. Yorks
Ta rolfw,
Sounds easy enough. I guess I just need another sky box.
Just been looking a freestat receivers. Looks good. I don't subscribe to any premium channels so would be ideal for me. Do love my SKY + though, but I assume can get receivers with hard drives anyway...
Cheers
fozz
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Yes, the Humax HDR, which is specifically for Freesat.
