skystar 2, what software please?
humber44
80cm dish, hotbird, windows xp, pentium 4,1.5gb ram
england
:confused I am a complete novice but keen, i am running windows xp and have my dish set on Hotbird and have a skystar 2 pci card set up with dvbviewerTE and have installed vplug and some viaccess keys but all i get is the FTA channels. I would like Eurosport,plus other channels is it available on here? any help on what is the best software and keys would be great.
Thanks for looking
Humber
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Hello
Welcome to the forum humber44
I am afraid you are about 3 years too late for anything worth watching on 13 East with the aid of keys, almost everything is secure now
humber44
england
Hi Topper,
Thanks for the welcome and your answer, so is there other ways of watching locked channels like with a cam etc or a patched box
Humber
Topper
No there is only card sharing left in general terms as everything is secure now and it is suspected card sharing will soon be dealt a blow for UK viewing anyhow
humber44
england
Thanks for your replys and help topper. do you know if the patched satellite receivers liek a comag or silvercrest work on any sats?
Thanks Humber
Low Profile
DM800HD, DM7000 80GB HD with Asus WL330 wifi + 2GB usb drive, Skystar2.3, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
Lot, Dordogne, Correze border.
Eurosport is broadcast in English on 11240 V 27500 3/4 (ESP Cyprus), and encoded in Irdeto (amongst others), the Irdeto Caid is 0604.
In theory you could download the plugin Wincsc and put it in your plugins folder. To test this you would have to search for a "Free cardsharing" server with Caid "0604", then enter the parameters into Wincsc. This would be for educational purposes of course, but I've got an inkling it might work.
Effectively you would be connecting to someone else's legitimate card over your internetwork.
humber44
england
Thanks Low Profile i will see how i get on and will let you know.humber
humber44
england
Hi Low Profile, i have got the wincsc plugin and extracted it to the plugins folder. i have vplug and yankse in there to which i couldnt get to work does that matter? should anything happen when you extract a plugin to the plugins folder. how do you input the parameters etc, think i need a walkthrough,thanks Humber
Eurosport in English is FTA on 19.2ºE analogue.
Low Profile
I'm not sure if yankse requires an additional dll in your dvb viewer root directory, personally I would scrap it (if you can't get it to work). I would download "Freepack 2.1", this has S2Emu and V_Plug bundled with an auto updater, so any keys - if available will be updated. The plugins should be accessible from the plugin tab on your viewer. I'm not that familiar with dvbviewerTE, so I can't really comment too much (I use DVBdream - because it configures codecs automatically). To use Wincsc just click on Wincsc > monitor then 'add' the server details.
humber44
england
Hi Low Profile, i have uninstalled dvbviewer and setup4pc, should i have left setup4pc on? dvbdream installed ok and i have scanned the channels on hotbird and they have listed ok, but i cannot see any video or audio free or encryted? also do i need to install a plug as there an empty folder at this time,
Thanks Humber
Low Profile
It's best to leave setup4pc installed. In DVBDream select options > video > Auto graph - if anything is pink then change it using the drop down tab.
If you haven't got a codec pack installed then now would be a good time to install one. Make sure DVBdream is closed when you do, then the codecs should be automatically found by DVBDream. Cyberlink is a good video codec, Nero will do 4:2:2 transmissions (for feeds), and intervideo is a good audio codec that doesn't appear to have any issues (so far as I'm aware).
humber44
england
Hi again. i had sorted my codecs outs and got the fta channels then i put v-plug and semu into the plugins folder and didnt get any other channels so i found the latest v-plug and keys installed them and now i have no channels even when i rescan, i have emptyed the plugins folder still no channels or signal,any body got an idea what i have done, Thanks for any help iam getting stressed here:confused
Might be a good idea to reinstall Skystar from scratch (drivers, Setup4PC), then DVBDream and emu plugin.
Topper
Llew said:
Might confuse the OP Topper. Not a Dreambox issue :eek:
Mmmm well spotted Llew, that will teach me for skimming. apologies to humber44
humber44
england
Hi, i sorted it out i rebooted my pc and the channels were there so i installed the plugins and keys and got it to work but iam bit late theres not much open so i have set up winscs got some info and need pointing in the right direction for up to date.
Thanks Humber
humber44
england
Hi folks, i have installed two or three free servers and input all the parameters some do not state what caid it is,but even the ones that do come up with an error when you add the port and when up look in the monitor the bottom two boxes right at the bottom say disconected and no server, are the servers dead may be? where is a good site to look,Thanks Humber
Low Profile
When you enter the parameters in Wincsc and add a port, you should be able to "Get CardData", this identifies if a server is active, and it's Caid's / encryption method. If the server is disconnected then the server is either not valid or not active for the channel / channel Caid you have selected.
A tip: in DVBDream, right click on the channel > channel properties, select a 'CA Type' that is the same as your server's Caid. If it's valid it should connect.
A search engine should find free servers, unfortunately you won't find that data on here.
