skystar hd2 setup?
krishn
dvb s2 usb for pc
india-gujarat
hi friends,
I am very new to dvb s, just installed pci dvb s2 card "technisat skystar hd2".
facing some problems given beneath.
1. installed software dvbviewer pro, but no channel scan is working. probably hardware not initializing.
2. i have then tried dvbdream but showing me error of hardware initialize error code 12.
currently I am trying to scan transponder and channel of insat 3c http://www.lyngsat.com/in3c.html
my hardware setup is
system: xp sp3, amd 3200+ 1gb ram.
sat hardware: dvb s2 pci card "technisat skystar hd2", ku band dish 60cm, lnb supports dvb s2, no DisEqc, direct cable from lnb to my pc card.
my location: 21n 72e, western part of india.
HB13DISH
Retired Mod
Middle East - Israel
krishn said:
hi friends,
currently I am trying to scan transponder and channel of insat 3c _http://www.lyngsat.com/in3c.html
Are you sure that you are pointing to the satellite?
Is dish size 60cm large enough for this satellite in your location?
Have you tried using standard receiver to scan the channels with success?
krishn
dvb s2 usb for pc
india-gujarat
i am 100% sure because I have just pulled out cable from my existing dth provider which you can find here h**p://www.lyngsat.com/in4cr.html and insert in to my new pci card.
In DVBViewer Pro, go to Options - Hardware and rescan the Mantis driver.
DVBDream has known problems with some BDA drivers, try this one -
krishn
dvb s2 usb for pc
india-gujarat
ok installed new driver now but no success.
krishn
dvb s2 usb for pc
india-gujarat
any good guide from which I can confirm that my card is working properly and getting signal?
Sotos65
Receivers: Edision Argus, Technomate TM-5300D+ USB, Skystar HD2
Dish: Tecatel 1.10X1.20
LNB: Sharp BS1REL100W
Sat motor: Moteck SG2100
PC: Cpu C2D E8400, 2GB.
Greece
DVBDream+Skystar HD2 will only work with a customed device file, called "BDA_ALL". There are two files, BDA_ALL.DEV and BDA_ALL.INI, you must put them in the "Devices" folder located in the root folder of your DVBDream installation.
As far as I can see the channels you are trying to receive could be the ones from the "Airtel" package, transmitted exclusively in DVB-S2. So in order to receive them with DVBViewer Pro you must go to Settings>Options>Hardware and make sure that the "Is DVB-S2 device" check button is selected. And finally you should check if your transponders .ini files are up to date.
Skystar HD2 works fine here with the latest drivers and those two programs...
  • BDA_ALL.zip
nebula
1.2 M STAAB motorised
C120 Invacom 0.3db uni LNB with feedhorn
Triple dragon reciever
Qualit-Tv
SatLook Digital NIT
Diablo light CAM, CAS2+
Aston crypt with digital + card
Sly mindish and subscription.
London
wow thanks alot Sotos65 for the helpful advice! my SS2 HD2 is working lovely now! Thankyou!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :)
