- May 26, 2020
- Raven mk2 zone 2 x4, Channel Master: 90cm x3, 1.2m x2, 1.8m PF. CM polar mount x2, Az/El x3.
- South Durham
When trying to nudge the dish using my V-Box, each nudge is usually two pulses. Would using a PWM motor speed controller like this work to slow the actuator down (or rather reduce time the power is sent to the motor) and achieve a one pulse nudge?
My thinking is - if PWM is set to 50% the motor will only receive power for half the time, and only move around half as far - unless the V-Box is waiting for two pulses before stopping.
https://www.amazon.co.uk/ARCELI-Upgraded-Controller-Regulator-Support/dp/B07MQ13ZGX/
