Today I've taken my 1.2m dish down and replaced it with a 1.5m dish. Have got a good signal again, and loads more channels, but with one crucial difference - there is no sound at all. Never had any sound problems before. Anyone help?
I've checked all the connections and they work. Should I have gone through a 'new installation'. All I've done is literally take the old dish down and put the new one up, moved it around a little 'til the strength/quality looked good and hey presto - no sound.
I have never had the sound affected when replacing a dish, if you are getting a good signal strength and good picture, you should have good sound. I would still suggest checking the scart leads as it doesn't take much to slightly disconnect one. If that doesn't work, then try switching the box off at the mains and resetting.
Yup, it's an easy thing to especially if it's your own equipment.
You know what you've been mucking around with and go for the most difficult possibility straight away. If it had been anyone else's stuff you'd follow the logical fault-finding route starting with the easiest first.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
