starcom sr-c6 software upgrade
deldadeh
starcom sr-c6
Iran
Hi all,
i have starcom sr-c6 receiver.
but i don't know how to update that?
it just has hot-bird satellite in it's list!
could you please help me on updating it?
where to download files? and how to use them?
thanks
deldadeh
starcom sr-c6
Iran
this is the back of the receiver!
could you please tell me what kind of cable i should use to upgrade it?
and how to make that cable!?
thanks
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Unless your setup is motorised you can only view one satellite at once unless you have a monobloc or multiple lnb's through a switch. Therefore why would you want to upgrade the software, what do you perceive this course of action could gain you.
Normally extra satellites and hence channels are added by moving the dish to point at the correct satellite then scanning
deldadeh
starcom sr-c6
Iran
thanks
i know
do you know anything about the cable?
Topper
Not really it looks like a four port motherboard connector not the same but similar to a CD data connector more than that I do not know never seen one on the outside of an stb before
deldadeh
starcom sr-c6
Iran
i know what connectors to use!
but i don't know how to connect pins together!
i mean the number of each pin on the back of receiver!
Topper
If I have never seen one before how could I know anything about it?
Try contacting the manufacturer, although you may need to learn Chinese
deldadeh
starcom sr-c6
Iran
why learn Chinese?
i contact the manufacturer! _www.starcomsw.com
but there is no response!
[nolink] Admin [/nolink]
