Starsat 346 550/650/3100/3200/3500 Super & Ultra
alainc
Aston Simba HD and some others.
Dish 2.00 m Hotbird 13°
saudi arabia
Hi alls
a new set of firmware release 346 are available on satdw for above receivers.
Working Auto Viacess on Hotbird.:)
Just wait on Viaccess channels after upgrading.
hope it's help
o_sir_je
Hotbard1,2,3-6, Nealsat,Asia Sat
hi, hope u r fine and doing ur work in good manners, i am the new user of this forum, today i read ur message, i think it is really very usefull, thank u very much, but if u don't mind can u told me how i can get this software?
if u tell me i am realy thank full u
Nouman
je_sir_je:-shhyahoo.com
KAKA12
Starsat 1500D ULTRA/150D V7/1M/2M
Hotbird
thanks tested ok !!
graovacb
Starsat SR 550, dish 130 cm fix
Serbia
I have Starsat 550 ultra with v.346_u_s and nothing happened. Does it work for TPS or not. Maybe I must use only ultra version?
alainc
saudi arabia
Hi je_sir_je
this sw is available on official site satdw.com
seems to me T*P*S has done some change till friday, so it don't work as fine as last week.
If you'll find a message "enter code" type 345300;
then go to parental lock and set up "scambled channels" to NO
Hope it's help
graovacb
Serbia
alainc
Now I installed v.346_ultra and I still have a problem. When I go to parental lock there is no "scrambled chanels" than something others. Please can you describe complete procedure for doing that, and can I anyhow get in part for changing keys. Thanks in advance
graovacb
Serbia
I have a few questions. How I can change the keys in my starsat 550 ultra? I can't find the way to do that. And, can anyone confirm that automatic update for viacces on Hotbird works on starsat 550?
gasth404
Starsat3500CUCIsuper
+Manhattan5900
+HumaxVA-ACI
motorised dish
Baltics
Not working TPS auto with V346!
NO menu INPUT CODE!
Not find something new but lose most channels with manually inputed codes.
alainc
saudi arabia
hi graovacb,
I've tested this realease on 3200 super. It's working fine during 2 days. After no more. On super version you have still input code menu and parental lock dialog boxes. But, as other auto update realease, if you enter keys by remote the auto search kill the one you've entered. The last one, not auto update with key by remote i've use for Ultra models is R 333.
Hope it's help
alainc
saudi arabia
Hi all,
a realease 348 for star sat DSR (3200 ...) is available on satdw:)
hope it's helps
mwahdan
Sat Lover
Starsat SR-X650CI Super
Cairo, Egypt
Hello alanic;
I am happy I found this page, it will help alot to understand so many htings.
I tried v348 for my starsat 650CI super, and I went to parental lock, and entered the code 345300 to open, and I choosen "no" for scrambled lock, and saved it.
But i did not succeed to open TPS. Can u advise what I miss?
Thanks, all for one, one for all.
kela
s
Hi all
no access for menu (345300) and for editing channels (987600) with starsat SR-X3100CU ultra V348.
do you have information about that?
thanks
alainc
saudi arabia
Hi mwhdan,
you're right T*P*S do not work normaly on 348 (for 346 it has work 2 days only); so you do'nt miss anything.
Sometimes it's work for 10 to 20 mn but next one fully scrambled!
we are all awaiting next realease from satdw.
Hope it's helps
alainc
saudi arabia
Hi all
new sw available on satdw for 550 - 650 - 3100 - 3200 - 3500 starsat dsr
auto update viacess. ok tested on 3200 super:)
finddubai
Starsat SR-X3300CU
Toshiba Laptop Serial on COM4
UAE
I need a software to update .hex file in Starsat 3300CU
I have used EMUpgrade but as my laptop will use COM4 and EMUpgrade doen't functioning on this port I can't use it.
anyone knows any other software that I can use?
Regards
alainc
saudi arabia
Sorry for you bbbggg,
Plus 1M starsat can not be patched with sw 349 till you add 1 more memory
1M + 1M = super or ultra model (2 M)
other way very old 146 realease on satdw
fselhami
Starsat X3100CU Super
dubai
Hi everyone, I downloaded V349 software on my Starsat 3100. It is working fine. Sometimes it takes long time to unscramble the TPS channels.
Let's hope it will continue
graovacb
Serbia
Unfortunately v 349 does not work automatic update for TPS channels on Starsat 550. Open that only for a few minuts and after that you must wait to long for opening again. Any help?
fiazasim
DEar i have a starsat 55o-d super tell me that is possible in feuture TPS channels working on my reciver or my reciver is full fail..............
