StarSat receiver (RS-X120D) Software Update Facing Problems Need Help
waseemahmad
Free To Air Satellite Receiver Star Sat RS-X120D & HP compaq 7400 with windows 7
Riyadh
I need Help,
Actually I am trying to update the software of my StarSat (RS-X120D) receiver. for the first time By self
I download the new software file from star sat website.
I prepare the RS232C Cable
I connect the receiver with my computer, and open the Loader program (emupgrade221)
emupgrade use comport1( I have only 1 comport in my computer where I connect the cable
I select the new file and start the up lode,
But the problem is
Nothing happen
Now can anybody help me & and guide me
how I can check the connectivity between Receiver and computer?
the cable is correct I check that with multimeter
Please Help me
You should be in download mode -
_http://sorna.esmartdesign.com/matn/upgrade_stb_en.pdf
waseemahmad
Riyadh
I check the cable with multimeter
Follow the same step by step
but still nothing happen.
Here I want to tell you about my STB.
Model ID=E124
H/W Ver =2.10
S/W Ver =2.56
You can see the attachment as I select the download mode
sweetsaint
Dream Box
Riyadh
can you explain the steps you are going through?
