STARSAT SR-X200CI upgrade
sreekumar
Hi friends,
Ineed patch for my STARSAT SR-X200CI in order to view some encripted chanels with out a fun card. pls tell me where can i find this patch and what is the name of this patch also hopw to do it.
waiting for your help,
narayanan
sandraekel
Hi, I was reading the threads here and would also like to know how and what I should do to my Starsat receiver SR-150D. I have had the receiver for three years and never upgraded it. I would also like to get the codes to open some of the channels (or all of them yipee), and would love for someone to give me some info onthis, can you help?
infosat1
behrooz1363 said:
be happy all.
I am a star-sat user.My receiver(starsat sr x-200ci) can open some channels like: EuroSport, BBC Prime, Boomrang, Animaux, and the channels like these.Is there any way to add more channels to see? Furthermore, I know nothing about giving codes or keys to,or programing the receiver can anyone help me about these or show me a PDF about these please.
thanks a lot.
hi for entering keys tou have to push on menu then when you go to stb then press 1234 it shows you 4 lists seca viaacess irdeto and nagra
then you enter any list you want to edit etcc
try this
its easy
PERVEZ
Arab
I need to upgrade my receiver SR - X200CI plus
zgzg2020
infosat1 said:
hi for entering keys tou have to push on menu then when you go to stb then press 1234 it shows you 4 lists S*ca viaacess irdeto and nagra
try this
its easy
YOU RULE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I'VE BEEN SEARCHING EVERYWHERE ON HOW TO ENTER THIS PAGE ON THE RECEIVER!!!!!
THANKS MAN!!! YOU ARE THE GREATEST!!!!
harrypotter
Hi please help me.
for programming my receiver (starsat X-200CI) i did:
1.Went to www.satsw.com.
2.Downloaded item number #11 which is loader(emupgrade)
for starsat and installed in my pc.
3.connect nine pin female+female(rs232c cable) for
connection between pc and receiver
3.Started the loader(emupgrade) and browse for bin file
sr-x200ci (I downloaded this file from www.satsw.com).
4.Checked my current model I.D, h/w version, s/w version
from STB status of my receiver and compared with the
laoded file on emupgrade.
5.my current model (receiver) is h/w ver=2.00 , s/w
ver=2.55 , model I.D=E224 and for sr-x200ci file was hw
ver=7.00 ,s/w ver=2.64 .model id=E224 ??? (after E244
was 3 question mark) therfore I pressed start button
of emupgrade for downloading.
6.Powered off my receiver from backside and restart
again.
but nothing happened !! what is wrong??
(maybe I should say peressing 1234 I
entered STB setting and I deleted all
viaccess codes manually)
please answer me what should I do step by step.
Have a nice time.
thanks a lot
harrypotter
Hi.
I want to update the programof my starsat sr_x200ci receiver but when I press menu and go to Instalation and then press ok on Transfer data nothing happens.
how can I transfer data between receiver and PC.
thank you.
Digital2
Dreambox 500s,Dreambox 800HD PVR,Max 1000,Vivax 505, Starsat 200CI. Desktop with WinXP, Laptop with Vista & Netbook with Win7. External HD/Media Recorder.Hotbird,Nilesat,Asiasat3S & Intelsat.
Middle East (Currently!)
You can find your answer at :-
h**p://www.satellites.co.uk/php-bin/forum/showthread.php?p=160051#post160051
{But for those of you who need some extra details, here they are:-
1.Go to www.satsw.com.
2.Download EMUpgrade (File No.10=Loader)
3.Download S/W cleaning zip folder ( http://www.satsw.com/Upload/sw_ver_clean_for_SR-X120,150,200CI.zip)Remove the previous software through this.
4.Download the Dec 18,19 program for ur model of Starsat. Unzip it. Browse to it through EMUpgrade (Loader), click start, turn ur reciever OFF and ON, wait until it tells you the upgrade is done! One good news, no need to use the dreamloader OR HEX file after the upgrade. All channels coming without doing that. }
Good Luck
