StarSat srx 2200ir - software
loribadeaux
starsat sr-x2200ir
Hello,
So I use a receiver StarSAt srx 2200ir.
To download keys into it I use Keymaker 1.9. So kbn files.
My dish is on Hotbird.
After writting the keys to the receiver, nothing extra is coming up. No tps, no french channels, no eurosport, anything except rai, and swiss.
Obvious I use the last kbn file.
I was trying to use other loaders like STB5518, Bali, emupgrade 2.2.4 ; they are not working with my receiver.
There is DnUP Man v. 5.3 which is said to be special for this receiver, but the keys are way back dated.
So my question is I am doing something wrong or this is suppose to be at least for the time being?
Like last week there was a patch .kbn file for 16-24 nov period which was working properly, but these everyday updated files are not doing the trick on my hardware.
Can somebody more knowledgable , clarify this for me, please.
Lori
DeepDiver
Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11
Mariana Trench - Pacific Ocean
Hi there,
you are doing everything well, using the correct software and files. But, currently TPS is not available on most systems. Therefore, on Hotbird, you will only get RAI and SRG Swiss.
You can read more about it here http://www.satellites.co.uk/satellite/digital-systems/83318-tps.html
It is reported to be working with K3 cards, and on Starsart srx 4000,4200,5100,5200. In these boxes, the manufacturer wrote a complete new set of firmware. Whether it will be done on other boxes of the same brand is not known at present.
Hope it helps.
