Mickha said:Stealth 232 is now available with yet another fix for Premiere AU
Mickha said:To get Premiere to work with older Stealth versions loaded you have to turn off the N2 AU feature, located in the configuration menu, before entering any keys, otherwise the AU will overwrite your new keys with fake keys.
If you load Stealth 228, or above, turn off the N2 AU feature, and enter the keys you will get all Premiere opening, including the PPV movie channels.
At present Stealth 232 is AU on Premiere, so you can load this, turn on the N2 AU feature, and the keys will update for you, providing you leave it on one of their channels for a few minutes.
Mickha said:You will need a Cas programmer anyway, to update the Diablo Cam, as new Stealth firmware is developed.
How are you entering the keys?
I always enter the Cam menu.
Select Keys, List Keys Edit, and then the required encryption.
For Premiere you select Nagravision 2, you then need to enter the keys for both 0501 Premiere and 0503 Premiere Star, they use the same keys but open different channels.
Try using a Free to Air channel if experiencing any problems.
You should buy a Cas programmer, preferably a Cas 3+, to get he most from your Diablo Cam.
Mickha said:Premiere doesn't always have an English sound track. Sci Fi, for example, only seem to have an English Audio track for Lexx and Farscape.
The Diablo also causes problems when switching between German and German 2 audio options.
I have all my premiere channels set to German 2 (English) by default so that if there is an English sound track I can receive it.
If you do need to alter the audio try removing the cam, changing the audio options, and the re-inserting the cam.
Other owners have found changing the audio option switching channels, and returning to the original channel works for them.
Some owners find changing the audio option and then turning off & on the receiver is the only way it works.
It's a case of trial and error to find the best method for your receiver.
Mickha said:Premiere is still AU (Auto Updating) with Stealth 232 but it does take a few minutes.
Have you got the right settings in the configuration menu?
Enter the Cams menu, enter configuration, and ensure the following are set to ON:
Auto PMT ON
Emulators ON
N2 AU ON
you can then alter the other settings to your preferences.
Emulators priority is best set 1 Emu 2 Cards, unless you8 have a subscription card in your cam, and I always leave the smartcard message to show, as when I see this I know the cam is attempting to update the keys.
If these settings are correct and it still isn't working try formatting your cam.
Insert your Cam, start up your Cas software, start up the Diablo software, click on the Cam Disk Functions tab and format.
Once complete click on the Upgrade Cam tab and load Stealth 232 again.
You will have to alter the configuration settings again after carrying out this process.
