Log in
Register
Menu
Log in
Register
Home
What's new
Latest activity
Authors
Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Forums
Satellite TV receivers & systems support forums
Satellite PC Card Receivers, Internet by Satellite
Strange and big problem with my SS2
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mastercare" data-source="post: 603672" data-attributes="member: 189980"><p>hi bombedone</p><p>i have a faulty skystar2 rev 2.3 would q13 gone have the effect on say astra only tuning taquilla chs?</p><p>i have found it on board marked ss it seems q14 is marked the same can i swap these around to see if diff fault occurs...i dont have nay mosfets here..</p><p>from pins of tuner starting away from F connector i have </p><p>1 = 5v</p><p>2= 5v</p><p>3= 0v same 4 5 6 7</p><p>8= 5v</p><p>9= 1.2</p><p>10=5v</p><p>11=1.02 rises to 3.6v when i run up dvb app and i have a fta ch on asta 19.2</p><p>12=5v</p><p>13=12.8</p><p>13=12.8</p><p></p><p>cheers</p></blockquote><p></p>
[QUOTE="mastercare, post: 603672, member: 189980"] hi bombedone i have a faulty skystar2 rev 2.3 would q13 gone have the effect on say astra only tuning taquilla chs? i have found it on board marked ss it seems q14 is marked the same can i swap these around to see if diff fault occurs...i dont have nay mosfets here.. from pins of tuner starting away from F connector i have 1 = 5v 2= 5v 3= 0v same 4 5 6 7 8= 5v 9= 1.2 10=5v 11=1.02 rises to 3.6v when i run up dvb app and i have a fta ch on asta 19.2 12=5v 13=12.8 13=12.8 cheers [/QUOTE]
Insert quotes…
Verification
Post reply
Forums
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
Accept
Learn more…
