stream FTA update
cisco_lad2004
Stream FTA + 2 LNBs
Astra / Hotbird
Hi Forum
I am terribly new to this. I have bought a Stream FTA 1000 while in Northafrica. It has no slots but was updated to receive all TPS channels + others. This is apparently required each month.
I came back equipped with an RS-232 or is 323 ? and started looking for firmware but in vain.
Can anyone help with a tutorial or links ? I am also interested in H** off line .
Thanks in advance
Cisco-Lad
cisco_lad2004 said:
Hi Forum
Thanks in advance
Cisco-Lad
If its this one:
StreamSystem BM-1000 FTA: DVB-S, 4080 Ch., FTA then its a rebadged Kaon.
cisco_lad2004
Stream FTA + 2 LNBs
Astra / Hotbird
It is exactely this one !
Cisco_lad
You are lucky theres loads of support for Kaons! :D
cisco_lad2004
Stream FTA + 2 LNBs
Astra / Hotbird
Is there really ? when I find a presumably good file, is there any way I can check it is the right one and would not kill my box ?
Cisco lad
cisco_lad2004
Stream FTA + 2 LNBs
Astra / Hotbird
Finally some light at the end of the tunnel!
The official stream support site is here:
h**p://www.streamsystem.com
although the front page has a lot of flash crap on it. The site gives some useful info, but there doesnt appear to have any software on it.
According to the receiver comparison site, these all appear to be the same rx
Digiquest 7000S: DVB-S, 4080 Ch., FTA
Digiquest 7000T: DVB-T, 1000 Ch., FTA
Ariza/ BlackBird/ CyclonePro Ultra 400: DVB-S, 4080 Ch., FTA
Although you may want to avoid any software for the 1000 channel rx!
cisco_lad2004
Stream FTA + 2 LNBs
Astra / Hotbird
Thanks again Analogue, but I am not suire I understand ur last comment. My RX is 1000 channels , are u saying I should not update it ?
another one, can I backup th ecurrent image in case update goes tits up ?
Cisco lad
I understood this bit:
to mean you have 4080 channels available. If you have indeed got 4080 channels, and you flash the receiver with software designed for 1000 channels, then it could end in tears.
cisco_lad2004
Stream FTA + 2 LNBs
Astra / Hotbird
Got u ! many thanks for ur help again
Cisco lad
setarehp
digiquset 7000s
london
Upgraded for DIGIQuest 7000S FTA needed
HOW CAN I :
UPGRAD
UNLOCK $
AND PLEASE TELL ME WHICH PROGRAMS I WILL INSTALL IT THAT MY COMPUTER SEE MY SATELLITES SO USE NULL CABLE PLEASE SEND ME TO MY ADD .... SHMS*BTINTERNET.COM
THANK YOU
