Strong STR 4355 Remote
HB13DISH
Retired Mod
Middle East - Israel
A friend of mine got Strong STR 4355 satellite receiver but without a remote.
Any idea where to get the original remote or any universal remote that can work with this model?
The manufacturer website doesn't list this model, even in the discontinued section.
Need the user manual as well.
Thanks for your help.
HB13DISH
Retired Mod
I got him a user manual and suggested to him to use the buttons on the box to do a new installation, without the remote.
There is Menu, Exit, Left, Right, Up and Down buttons.
But the odd thing is that there is a request to input the PIN number, but without the remote it is not possible to do this.
Is there any way to override this in the meantime until a remote is bought?
nelson_b
Contributor
hi -- HB13DISH ---
there is no way to input numbers witout a remote -
i got a strong 4375 a while ago -- no original remote --
but it had with it a -Gemini - G310S - 3 device universal remote
which worked o.k. for 95% of the functions -- although it took a while to get used to "which" button worked "what"
the same remote -- on the same setup code worked ok on a
Strong 4155 Evolution which i also recently bought without a remote
regards - nelson_b
HB13DISH
Retired Mod
nelson_b said:
hi -- HB13DISH ---
regards - nelson_b
Thanks nelson_b for your input.
I got information where to get original remote for STR 4355 costs 10 euro plus shipment so my friend is going to order it.
If you want original remotes for your boxes, I will be glad to help you.
nelson_b
Contributor
hi - glad you got sorted --
yes i am interested in getting an original remote for the strong 4375
regards - nelson_b
HB13DISH
Retired Mod
regards - nelson_b
Hi nelson,
Please check your PM.
jimbofz
fta 1.4mtr dish
uk and spain
hi i know its a while since this post ,but i would also like to know where i can buy a remote for str 4375 can anyone help
nelson_b
Contributor
hi - using a e mail adress i got from member -- HB13DISH --
i contacted " strong " but the remotes for 4375 are no longer available ---
A -- Gemini G3105 - 3 device universal remote will work on the 4375 -- using code 545 -- you will need to re label some of the buttons on the remote until you get used to the layout -- but it will do practicaly all the menu functions --
regards nelson.b
