blademedia
- Jul 29, 2016
- Sky
- UK
Hallo our TV is 4k but will a Technomate TM-5402HD C1+ Super + receive the signals and find it on a blind scan ?
Regards Spiff
Regards Spiff
Amiko A3 combo
I am getting my quotes and reply mixed up I think ?Some 4k channels will scan in as radio, if you insert usb and record you can play back using vlc player
Thank you for your reply : )
After a quick look at both receivers on eBay, it would appear the Mutant HD51 though a lot more expensive is sat only, where as the Amiko A3 combo covers terrestrial TV as well.
I wonder do you use one of the two ?
Not sure if there are any 4k stations on terrestrial in the UK yet via Freeview ?
One of those two would make a nice Christmas present, time to drop some hints I think : )
God Bless Spiff
so record the 4k then plug drive into computer and use VLC player.
No,I am assuming there is no way to install the VLC player on the Technomate ?
The mutant has plug and play tuners, its ok for whatever your needs areit would appear the Mutant HD51 though a lot more expensive is sat only
Yes
No,
But there is a work round, use wifi usb while recording stream it over your network to pc, then stream from pc to tv, bit of messing around but it works,
Oh yes that's true but there's no blind scan with the mutant it seems ?
