T-888
usman ghani
technosat
pakistan
I have a technosat T-888 digital receiver, 1mb flash memory and I have a 9-pin female (at both ends) upgrade cable,receiver has female pin and pc has male pin, I also have gender changer for upgrade cable, have a technosat T-888 software both 1mb patched and 2mb patched to upgrade,I want to ask you that which of the software I need to upgrade 1mb or 2mb, when I upgrade from 1mb
I see this error "can’t open connection, maybe com has been opened, com is open", I see also "please reset the receiver, waiting for sign from " boot loader" =>" and how can I reset the receiver when there is no reset button. Please reply me with your best I will be very thinkful to you,if you don’t reply please refer me to your best .thanks a lots. Thanks…..
tamazgha2003
dreambox 500s
tamazgha
reset receiver=cut off the powerand on again(receiver off and on again with the powercord)
