T K BRACKETS size
den123
ddcccccc
uk
hi guys what size t k brackets are best used so dids wont bang into wall
Depends upon size of dish, orientation of wall and desired arc limits.
More info, please.
den123
ddcccccc
uk
1 meter dish south facing high up
den123
ddcccccc
uk
what sats should i get without hitting wall
Even with 12" T&K, in your circumstances you should be able to track 60 degrees East and West without issue, assuming you are going to use a generic H-H DiSEqC Motor (Which, of itself, increases the standoff from the wall).
Using bigger T&K will look ungainly and add no value.
den123
ddcccccc
uk
hi was going to use the stab 120
For increased stability - to save maintenance trips up to the mounting point - you might consider TTK or TKK.
ie A third bracket suitably placed.
Which of those two configurations is best has been debated many times. My own view is that either will do, but others might well disagree!
den123
ddcccccc
uk
have put tk tk so 4 brackets
Wow, that's going to be indestructible!
den123
ddcccccc
uk
Hope so mate it gets bloody windy high up lol lol
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Got 2 dishes on usals motors on one long pole ...mounted on 2 Ts and 2 Ks . It goes T -K- K- T ..12 inch stand off ..
TD110 at the top ..Orbital 1m midpoint (which is down for maintainance atm)
60E to 60W ...but the Troublesome Tree masks part of the lower Orbitals Eastern arc..
rgds
VS
