Vipersan
Emmett Browns Ghost
- Jun 29, 2009
- Age
- 67
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
- UK
Hi friends ..
Not been fit to climb ladders and work on the dishes for a couple of days ..so decided to work on my latest creation..at ground level..
All cut from a section of 1/8th thick Aluminium I section bar..
Feature a simple clamp design to fasten around the lnb support arm ..
This can move backwards and forwards for focus ..
And a sliding key slot to allow some lateral movement of the lnb.
I've retained some of the I section in the form of a T ...to provide a support rib ..and therefore strength vertically..
Can't try this until the stainless steel m5 nuts & bolts I've ordered arrive ..and I'm fit to go up the ladder.
But hopefully this will allow a Cband lnb to be fitted approx 4 degrees offset to the focus on the TD110.
Now that lightweight black ultras have been fitted on the TD110 ..
The considerably reduced weight at the end of the lnb arm ..will hopefully make less of a weight issue with regard to fitting this new Cband assembly
rgds
VS
rgds
VS
