Technisat Skystar2
selvam
12 Feet "C' Band dish, and 90cm offset "Ku" Band Dish,Nokia Mediamaster 9200S Receiver with DVB2000 software,Metabox-1, HumaxVACI-5300.
Dear Members,
Is the Technisat Skystar2 V.2.6 PCI Card is capable of decoding DVB-S2 signals.
HB13DISH
Retired Mod
Middle East - Israel
selvam said:
Dear Members,
No.
You will need SkyStar HD2
_http://www.technisat.com/index4986.html?nav=PC_products,en,76-215
selvam
HB13DISH said:
No.
Dear HB13DISH,
Thanks for your advice and reply.
leebobslee
skystar HD 1080i sat +pci cam card.
vista premium 32bit,
geforce 8800 gtx directx 10
uk-hull
hi i have a skystar hd2 how do i get itvhd or ch4hd and they are not found when i do a scan can anyone help me)(-red
HB13DISH
Retired Mod
Does your PC meet the system requirements of the card?
Vista Premium?
Shouldn't have any problems scanning those channels in if you're correctly pointing to Astra 28E.
For ITV HD, enter the parameters shown here in your application (presumably DVBviewer, but will be similar for others).
You won't open Ch4 HD unless you have a CI module married to your Skystar HD2 in which to use an appropriate CAM and Sky card.
Low Profile
DM800HD, DM7000 80GB HD with Asus WL330 wifi + 2GB usb drive, Skystar2.3, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
Lot, Dordogne, Correze border.
I've managed to decode HD feeds by reducing my screen quality to 16bit and reducing the screen resolution to 800x600.
Kind of defeats the object if a non HD signal is available though.
HB13DISH
Retired Mod
Yes, but perhaps you can record HD channels instead of SD
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
if you want to make blindscan ,with the skystar 2 make sure you buy version 2,3C,all later version and revisions ,are not compatible,with this nice blindscan tool!
Low Profile
Re 2.3
It's a shame that Altx's blindscan tool doesn't work with later drivers.
Bxs will work (so long as you have Setup4PC running), but it doesn't have dynamic fine tuning (dependant on the S/R) like Altx's does.
You can also blindscan using DVBDream if you set up a transponder ini file without symbol rates like this:
1=10715,H,0
2=10727,H,0
3=10739,H,0
4=10751,H,0
leebobslee
uk-hull
my (skystar hd dvb s2 mpeg 4 with cam) can only get the bbc hd(ch)my TechniSat TV Center seems ok and my dish seems fine to ,is TechniSat TV Center,anygood,if not what is and were do i get it .DVBviewer will not work with my vista 32 bit i can make it worc on xp only???
I use DVBViewer Pro -
_http://www.dvbviewer.com/en/index.php
Works well with the Skystar.
Others to try are DVBDream, ProgDVB or AltDVB.
leebobslee
uk-hull
(Thanks) but still4 no joy, i have dvbviewer,CyberLink PowerCinema,DVB Dream,TechniSat TV Center, and ProgDVB 6 can,t see the card .I can see ch 4 hd now on (sky bsb)( blocked) but no itv hd.
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
can someone upload,all this tools,here,or a link to a website,i dont have tested them all yet:)
No problem with my DVBViewer Pro. You can receive Brit Shorts on that frequency I assume. Change the parameters as posted before, rename it ITV HD and click 'Add' to place it in your channel list on the left.
Showing ITV programming ATM.
leebobslee
uk-hull
(thanks) i got itv hd to work but now it will not work ?
G
guest
Air time is really very sparse at present, so it's there when it's there!
Here's the latest schedule:
Wed 4th 8pm FA Cup: Everton v Liverpool
Thu 5th 9pm Piers Morgan On...
Sun 8th 8.30pm Wild at Heart
Sun 8th 11.15pm Film: Shakespeare in Love
Wed 11th 8.30pm Football: Spain v England
Thu 12th 9pm Piers Morgan On...
Sat 14th 12.10pm FA Cup: Swansea City v Fulham
Sun 15th 4pm FA Cup: Derby County or Nottingham Forest v Manchester United
Sun 15th 8.30pm Wild at Heart
Mon 16th 10.35pm Film: American Pie
Wed 18th 10.35pm Film: American Pie 2
Thu 19th 9pm Billy Connolly Journey to the Edge of the World
Between advertised programmes, a station ident is usually shown (not always though).
leebobslee
uk-hull
(BIG THANKS) :-worship your the main man:cool: .It dose work,can you get me any more itv hd times if not were from. ps (THANKS)
Glad you've got it working OK.
A regular check of this site has forthcoming programme details -
_http://www.joinfreesat.co.uk/index.php/freesat-channels/itv-hd-schedule
