Telstar 10 at 76.5°E
genius5000
hi there
i am based in germany
what chances do i have in order to receive the C-Band channels
from Telstar 10 at 76.5°E in a standard quality?
thanks
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Germany is a pretty big place your precise location would be more useful or your longitude, however looking at the footprint it would appear you are right on the limit with that, your dish would be looking at the horizon. The further East you are the more chance you would have of reception but line of sight could also be a problem. According to the footprint map for Telstar 10 a 1.5mtr dish should be enough if it is above your horizon and you have line of site, it is too close to call just from your given location of Germany. What channel were you hoping to get?
genius5000
thanks very much Topper
well, basically i'm after these following 8 Bangladesh channels
3787 H ETV 4600-2/3
3840 H My TV 27500-3/4
4034 H Channel I 4300-3/4
4049 H Bangla Vision 3600-3/4
4089 H Boishakhi TV 4300-3/4
4095 H Channel 1 4080-3/4
4173 H RTV 7400-3/4
4173 H NTV 7400-3/4
i am currently in Hannover, but soon will move to Cologne
please do give me some ideas about the C-Band dishes, receivers, LNBs, Motor
i do own a Humax iCord ... will it work for C-Band?
i wouldnt mind keeping the C-Band with separate devices though
where are you based in anyway ...
could you perhaps check out those channels from your location?
that'd be brilliant!
cheers
Topper
Cannot help you out there, have absolutely no chance in the NW England of receiving those C band transmissions the satellite is below the horizon to me, you will need a C band lnb and I just had a quick look at the specs of your PVR it does not appear to handle C band but I would recommend you check with humax themselves before buying another receiver.
_http://www.humaxdigital.com
This is just a hobby I am not in business and have no experience of C band transmissions.
genius5000
i'll check out the other humax receivers
so 1.50cm dish will do the job then?
should it be mesh or offset?
what sort of c-band LNB in this case?
local satellite shops seem to have very little knowledge on c-band stuff here in germany
thanks again
Montafon Guy
4,5 m Andrew -Multifeed C/Ku Band
Austria
Hello Genius5000,
180 Mindestdurchmesser! ( besser 240 )
Im sorry - but 150 would not work!!!!!
Regards Montafon Guy!
genius5000
Montafon Guy said:
Hello Genius5000,
hey Montafon Guy
thanks very much mate
so wie solte das funktuniert ... do you actually have a dish which is 240m?
if yes, could you perhaps check if you can receive those channels from where you live in germany?
vielen dank
Montafon Guy
Austria
Hello genius5000!
I had a 2,4m a Year ago - and every channel worked here in Western-Austria..
ralphmagno
naples italy
hello to all,
i saw this and wanted to see if anyone has any information on this satellite.
the c band reaches all of europe and italy it comes in at 39 dbw or in c band terms a 1.60 meter should work fine here.
at 3.960H there is a hbo asia packet and it uses digicipher 2.
the same packet used in all asia.
this hbo asia is almost the same as the usa packet ,the programing is all in english,no subtitles and a week behind gthe usa.
transformers the move just played in the usa on hbo and its on 21 dec on hbo asia.
other satellite lists say this in not there anymore, some say it is still there.
if anyone has any information please feel free to give any advise.
thanks
ralph:-doh2
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
the only thing i could get from there was TVmaldives ,but with very intermitent signal (other word very weak)..using 1.50 offset dish and DMS BSC421 LNB on linear polarization ..located in south east of spain..regards
BombedOne
Republic of Georgia
I'm receiving this one with 160cm primefocus, signal not very strong, but stable, no drops. I'm watching mostly MCM POP, MTV BASE channels from it :) Since in VIA1 :D but in MPEG4 :( :)
doktorofsat
C BANDIT
QTH
I can receive from this bird to following ch with 150cm PFA+MTI 15k lnb:
TV Maldives power tp "4030 V 6312 1/2"
Channel I...................4034 H 4300 3/4______
|both with strong signal
Bangla Vision................4049 H 3600 3/4___
RTV , NTV ......................4173 H 7400 3/4( Bangladesh)
Boishakti tv...................
4009 H 4300 3/4
Desh tv..........................
4015 H 4340 3/4___
lower signals
ISLAMIC TV....................4146 H 3600 3/4 ___
BBC PERSIAN..................4073 H 13021 1/2
In the summer I was able to receive 3840 H 27500 3/4 ,used to watch Love music India and Democratic Voice of Burma, but I doublechecked and I have no signal at all :eek:I upload photos with the channels the last 3 are made in late august Love music India ; Democratic Voice of Burma and Sonar Bangla TV(whick dissapeard ;))
doktorofsat
C BANDIT
QTH
4009 H 4300 3/4
4015 H 4340 3/4___
lower signals
